JohndB
Jul 03, 2018Initiate
Wifi on VLAN GC728X
Hi There,
I have a customer with an GC728X switch.
There are two network configured on a Ubiquty Wifi AP and an Ubiquty gateway.
192.168.1.x for the business LAN and wifi
200.254.254.x for a wifi guest network with VLAN ID 20
The wifi ap is connected to port 13
I've made all the ports a member of VLAN ID 20 and VLAN ID 1. I can connect to the wifi guest network but do not receive an IP Address.
Can some please tell me how to configure this?
Thanks in advance!
Best regards,
John
Hi JohndB,
Welcome to our community! :)
You may need to assign the ports as T or Tagged going to the router and to your AP so that it can passthrough the VLAN in your switch. Please make sure that every VLAN aware devices was set to Tagged.
e.g.
GC728X
Port 1 - Ubiquity Gateway
Port 13 - Wifi AP
VLAN 1
Port 1 - T - PVID 1
Port 13 - T - PVID 1
VLAN 20
Port 1 - T - PVID 1
Then try to do ipconfig/renew and let's see if it will now provide an IP.
- JohnC_VNETGEAR Employee Retired
Hi JohndB,
e.g.
GC728X
Port 13 - Wifi AP
VLAN 1
Port 1 - T - PVID 1
VLAN 20
Port 1 - T - PVID 1
- JohndBInitiate
Thanks JohnCarloV,
It's solved now and I've learned someting ;-)Best regards,
John
