JohndB
Jul 03, 2018Initiate
Wifi on VLAN GC728X
Hi There, I have a customer with an GC728X switch. There are two network configured on a Ubiquty Wifi AP and an Ubiquty gateway. 192.168.1.x for the business LAN and wifi
200.254.254.x for a wif...
- Jul 04, 2018
Hi JohndB,
Welcome to our community! :)
You may need to assign the ports as T or Tagged going to the router and to your AP so that it can passthrough the VLAN in your switch. Please make sure that every VLAN aware devices was set to Tagged.
e.g.
GC728X
Port 1 - Ubiquity Gateway
Port 13 - Wifi AP
VLAN 1
Port 1 - T - PVID 1
Port 13 - T - PVID 1
VLAN 20
Port 1 - T - PVID 1
Then try to do ipconfig/renew and let's see if it will now provide an IP.
JohnC_V
Jul 04, 2018NETGEAR Employee Retired
Hi JohndB,
e.g.
GC728X
Port 13 - Wifi AP
VLAN 1
Port 1 - T - PVID 1
VLAN 20
Port 1 - T - PVID 1
- JohndBJul 05, 2018Initiate
Thanks JohnCarloV,
It's solved now and I've learned someting ;-)Best regards,
John
