winc
Jul 23, 2024Guide
I have a GS752TPPv3, Serial Number: 77W132D2007FF. I registered the device but Insight says it is no
I have a GS752TPPv3, Serial Number: 77W132D2007FF. I registered the device but Insight says it is not registered. I have never logged into the box but need to log in now and cannot. Is there a GUI p...
- Jul 24, 2024
There is almost certainly no Web UI on any unmanaged GS108. Could be some GS108E or GS108T model variants.
schumaku
Jul 23, 2024Guru - Experienced User
All documentations are readily available here -> https://www.netgear.com/support/product/gs752tppv3/#docs so please start consulting the fine User Manual.
Talking of Insight, there is always a product registration (for warranty and support purposes). Insight is "just" adding a generic and universal global config spanning an organization or location for example.
These are all Smart Managed Switches, so the primary UI is the local Web UI as described in the User Manual. This is why I'll challenge moderator moving this thread to the more applicable Plus And Smart Switches Forum section to discuss Smart Switches (T) and Plus Switches (E), including Local and Remote Management.
-Kurt.
- wincJul 24, 2024Guide
Thank you Kurt. Even though my DHCP server was indicating the correct MAC for the GS752TPPv3 switch (and it showed the assigned IP for the GS752), when I tried to access the GS752, the browser kept bringing up an unmanaged GS108. I finally was able to get into the GS752 by powering down the two GS108 switches that I have (neither of which are managed switches). Still scratching my head on this one.
