Michoc33
Feb 17, 2022Aspirant
Netgear GS728TP - Disable & Enbale PoE commands
Hi, I would like to know if i can enable & disable poe functionality on some switch ports (Netgear GS728TP model). I have an automate in a room, and i would like to be able to cut certain conf...
schumaku
Feb 17, 2022Guru - Experienced User
WebUI or SNMP only, no supported and documented CLI in general on the Plus and Smart Managed Pro models.
Selected newer models (as of writing GS728TPv2/GS728TPPv2/GS752TPv2/GS752TPP 6.0.10.5 and above, GS308T/GS310TP 1.0.5.5 and above, GS108Tv3/GS110TPv3 7.0.9.5 and above, GS724TPv2/GS724TPP 2.0.8.5 and above, MS510TXM/MS510TXUP 1.0.5.5 and above) are supporting a Lite CLI Configuration on Select Smart Switches
Michoc33
Sorry, it's indeed the GS728TPV2 (Part Number GS728TP-200EUS).
If so, where can i pick up all CLI ?
- schumakuFeb 17, 2022Guru - Experienced User
All you should need is on https://www.netgear.com/support/product/GS728TPv2.aspx
Current firmware -> Downloads
CLI Manual -> Docs
PoE example included when I have it right, at least for disabling it.
A related Blog post Update: Lite CLI Configuration on Select Smart Switches was published yesterday 8-)
