Michoc33
Feb 17, 2022Aspirant
Netgear GS728TP - Disable & Enbale PoE commands
Hi, I would like to know if i can enable & disable poe functionality on some switch ports (Netgear GS728TP model). I have an automate in a room, and i would like to be able to cut certain conf...
Michoc33
Sorry, it's indeed the GS728TPV2 (Part Number GS728TP-200EUS).
If so, where can i pick up all CLI ?
schumaku
Feb 17, 2022Guru - Experienced User
All you should need is on https://www.netgear.com/support/product/GS728TPv2.aspx
Current firmware -> Downloads
CLI Manual -> Docs
PoE example included when I have it right, at least for disabling it.
A related Blog post Update: Lite CLI Configuration on Select Smart Switches was published yesterday 8-)
