RayIT
Mar 14, 2025Aspirant
Question on Email from Netgear
Forgive my ignorance on this subject. Received this from Netgear.
The free bundled Insight support that were included with the Insight devices below will expire on March 28, 2025. Each device w...
schumaku
Mar 14, 2025Guru - Experienced User
In case you had used Insight for configuring and operating the Netgear devices listed and if you intend to continue using Insight before these licenses expire - the answer is probably yes.
