Lsands
Apr 15, 2024Tutor
GC510P shows disconnected but is working
Symptom: Insight shows 4 of my 6 switches as disconnected, but they are working fine. I have 6 GC510P switches at a location. When looking at the switches, they all show they are connected to the...
schumaku
Apr 22, 2024Guru - Experienced User
The switches try to establish a cloud session -to- the Insight infrastructure.
Anything changed in the data path prohibiting the switch LAN IP addresses to reach the Internet?
Lsands
Apr 22, 2024Tutor
Thanks for your reply.
The path was interrupted when I updated the firmware on another switch. That switch connected the network to Internet. Once the pathway is restored, I expected the switch to talk with Insight. What I find crazy is that the blue light on the switch is lit. That indicates there is a connection to the Internet. The only way I have found to get these devices to appear connected in Insight is to power cycle them, and that doesn't always work. Clearly Netgear has a software bug.
