ee1996
Oct 20, 2023Initiate
Wired MS80 works but app shows disconnected
Odd situation,
I've been troubleshooting my MR80 and 2 MS80 Satellites. I have one MS80 (Living room) Wireless backhaul and one MS80 (Barn) Wired at about 160 feet of CAT6. The Wired Barn is getting a normal 100-150Mbs down but the MR80 base indicates that it's disconnected.
I just updated everything to V1.1.7.14
my ethernet cable tester says everything is fine on the cable. I was able to direct connect between the MR80 and the MS80 with a short cable to get the upgrade done.
I don't see how the system will work but display that it's disconnected.
Thanks!
Thanks much for the response. I bit the bullet and did a factory reset. For this instant in time, everything is working. Over the last couple of days it'll work for a few hours then bail. Fingers cross that it'll remain stable. I'll try to figure out how to mark this as resolved. 🙂
Thanks again!
If it says its down in the app, what does it show in the GUI? (through the browsers)
It wouldn't be the first time the app wasn't correct
- ee1996Initiate
Thanks again!
Now try this!
You may need it in future.
