Theolodian
Mar 29, 2018Guide
SFP+ RJ45
I am running a 110P on a bonded trunk pair from a 728XP. I was hoping to use the 1Gbps SFP ports on each of the switches to do this and keep the PoE ports free. However, neither one of them likes the...
- Apr 24, 2018
OK, the cheap SFP to RJ45 adapters work if you only use them on one end. The other end must go into a normal RJ45 port. No idea about the official ones, but this is good enough for now. At least I can use all 10 ports on my GC110P.
schumaku
Apr 25, 2018Guru - Experienced User
Ok. Reason asking was that I'm trying to configure a similar set-up - with no-name/FS SFP 1 GbE copper modules in a GC510PP linking to another Netgear switch with SFP ports in a 802.3ad LAG - but all managed within Insight. And similarly struggling on unreliable connectivity results, too.
Theolodian
Apr 25, 2018Guide
I currently have a GC728XP and two of GC110P. The GC110Ps are each running on a LAG bonded pair into the GC728XP, which then has a 10Gb SFP+ DAC into an M5300 L3. I am not using the SFP ports on the 728 for the 110s, just the normal ports. One of the 110's is using the cheap SFP adapters. It seems happy but there is a red circle slash on one of the SFP ports in the app - not sure what that means. The other 110 I have not been able to move onto the SFP ports, even one SFP port plays up. Haven't had a chance to do a lot with it because people are using that one during the day. Everything is currently on local management except that one 'test' 100 that is using the SFP ports.
