Theolodian
Mar 29, 2018Guide
SFP+ RJ45
I am running a 110P on a bonded trunk pair from a 728XP. I was hoping to use the 1Gbps SFP ports on each of the switches to do this and keep the PoE ports free. However, neither one of them likes the...
- Apr 24, 2018
OK, the cheap SFP to RJ45 adapters work if you only use them on one end. The other end must go into a normal RJ45 port. No idea about the official ones, but this is good enough for now. At least I can use all 10 ports on my GC110P.
DaneA
Apr 02, 2018NETGEAR Employee Retired
Hi Theolodian,
The AGM734 would be compatible to both GC110P and GC728XP switches. As reference, kindly check the data sheet of the respective switches below:
GC110P Data Sheet - check Optional Modules and Accessories page 15
GC728XP Data Sheet - check Optional Modules and Accessories page 15
Refer to the table below:
DaneA
NETGEAR Community Team
- DaneAApr 09, 2018NETGEAR Employee Retired
I just want to follow-up on this. Let us know if you have further inquiries.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
- TheolodianApr 09, 2018Guide
I guess technically it is a solution. However it is not a practical solution as it is cheaper to buy more switches than buy the official adapters.
- TheolodianApr 24, 2018Guide
