Theolodian
Mar 29, 2018Guide
SFP+ RJ45
I am running a 110P on a bonded trunk pair from a 728XP. I was hoping to use the 1Gbps SFP ports on each of the switches to do this and keep the PoE ports free. However, neither one of them likes the...
- Apr 24, 2018
OK, the cheap SFP to RJ45 adapters work if you only use them on one end. The other end must go into a normal RJ45 port. No idea about the official ones, but this is good enough for now. At least I can use all 10 ports on my GC110P.
DaneA
Apr 09, 2018NETGEAR Employee Retired
I just want to follow-up on this. Let us know if you have further inquiries.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,
DaneA
NETGEAR Community Team
Theolodian
Apr 09, 2018Guide
I guess technically it is a solution. However it is not a practical solution as it is cheaper to buy more switches than buy the official adapters.
- TheolodianApr 24, 2018Guide
- schumakuApr 25, 2018Guru - Experienced User
Haven't used the two SFP+ ports for the modules on the GC728XP by error? Asking because of the subject "SFP+ RJ45" - SFP+ ports ... and these SFP+ ports don't support any kind of speed negotiation so GbE SFP modules can't work reliably in an SFP+ port.
- TheolodianApr 25, 2018Guide
Sorry about the confusing title. I am trying to use them in the 1G SFP ports. I'm still not getting consistent results so probably best avoided, but it means that the GC110P is really only an 8 port switch for most people.
