Theolodian
Mar 29, 2018Guide
SFP+ RJ45
I am running a 110P on a bonded trunk pair from a 728XP. I was hoping to use the 1Gbps SFP ports on each of the switches to do this and keep the PoE ports free. However, neither one of them likes the...
- Apr 24, 2018
OK, the cheap SFP to RJ45 adapters work if you only use them on one end. The other end must go into a normal RJ45 port. No idea about the official ones, but this is good enough for now. At least I can use all 10 ports on my GC110P.
Theolodian
May 03, 2018Guide
OK, it does seem to be completely down to the firmware update. The 'one end' that worked before was on 1.0.4.6 while the other end was on 1.0.2.11. Updated the GC110P that didn't work to 1.0.4.6 and it works, backdated it to 1.0.2.11 and it doesn't work, update it again and it does work - no changes to the settings. I would confirm the rest but 1.0.4.6 isn't available to download for the GC728XP yet, and there are some other issues with 1.0.4.6 at least on the GC110P.
schumaku
May 03, 2018Guru - Experienced User
It can be discovered via the GC728X (yeah, only) download - https://www.netgear.com/support/product/GC728X.aspx#Firmware%20Version%201.0.4.6 or direct on the GC728X / GC728XP Firmware Version 1.0.4.6 - the effective download URL does also unveil another secret - an upcoming GC752[X|XP]. No idea why the effective GC728XP download page was not updated - bradleyv can you check?
- TheolodianMay 03, 2018Guide
Thanks. Yeah, I have downloaded it from there but am waiting for answers on my other issues before I try it. Having to reboot twice to change any settings is not an option right now while I am still configuring everything.
