DooMMasteR
Jun 18, 2021Tutor
SFP Tranceiver for 1000BASE-BX10
So I recently tried some of my many SFP-BiDi Modules (BX10) but they either are rejected straight away or no link up is happening on them (physical works, but nothing else). I tired a Ubiquiti tr...
schumaku
Jun 19, 2021Guru - Experienced User
To my knowledge, Netgear does not intentionally reject SFP modules in this switch class as there is no spec limitation. Appears there were some other GC110/GC110P customers which found industry standard compliant modules (from wally brain variants for 1G copper Ethernet) not workable in these switches, too.
FWIW we're operating various original Cisco SMF modules (with Cisco brand and model ID in Flash) in GC110P and similar GC and other SmartManaged Pro Netgear switches.
More food for the Ntgr switch engineering DaneA
liquidate
Aug 01, 2021Initiate
Fwiw, I ran into the same problem with two GC110P switches and two different transceivers brands (qsfptek and 10gtek) that I purchased on Amazon. Based on a forum thread, I rolled my firmware back to 1.0.5.32 and both transceivers started to work immediately.
- DooMMasteRAug 01, 2021TutorHmmm yeah even my Netgear modules do not work.
There seem to be a serious issue with them... wow
