DooMMasteR
Jun 18, 2021Tutor
SFP Tranceiver for 1000BASE-BX10
So I recently tried some of my many SFP-BiDi Modules (BX10) but they either are rejected straight away or no link up is happening on them (physical works, but nothing else). I tired a Ubiquiti tr...
DooMMasteR
Aug 02, 2021Tutor
I am not sure what your point was. But now knowing that even Netgears own module does not work with current firmware, bit all of them work with older firmware versions, I guess Netgear broke something and they will have to fix it.
I will not randomly buy modules, and I also need BiDi modules (single fiber), not the usual stuff (though they are not really uncommon anymore).
schumaku
Aug 02, 2021Guru - Experienced User
DooMMasteR wrote:
... I also need BiDi modules (single fiber), not the usual stuff (though they are not really uncommon anymore). ...
Hope you are aware that Netgear does not offer and test (read: support) any BiDi modules.
It's not a question of common and uncommon - BiDi is still used mainly with ISPs for end-user service access channels, and not in business networks.
- DooMMasteRAug 02, 2021TutorI tried a normal duplex module... The error is the same.
With older firmware I have not found any module that does not work, Dell, Ubiquiti, Cisco, HPE, Netgear and FS.com all work fine.
Wir current firmware none of the modules work.
All give the same error.
