DooMMasteR
Jun 18, 2021Tutor
SFP Tranceiver for 1000BASE-BX10
So I recently tried some of my many SFP-BiDi Modules (BX10) but they either are rejected straight away or no link up is happening on them (physical works, but nothing else). I tired a Ubiquiti tr...
schumaku
Aug 02, 2021Guru - Experienced User
DooMMasteR wrote:
... I also need BiDi modules (single fiber), not the usual stuff (though they are not really uncommon anymore). ...
Hope you are aware that Netgear does not offer and test (read: support) any BiDi modules.
It's not a question of common and uncommon - BiDi is still used mainly with ISPs for end-user service access channels, and not in business networks.
DooMMasteR
Aug 02, 2021Tutor
I tried a normal duplex module... The error is the same.
With older firmware I have not found any module that does not work, Dell, Ubiquiti, Cisco, HPE, Netgear and FS.com all work fine.
Wir current firmware none of the modules work.
All give the same error.
