DooMMasteR
Jun 18, 2021Tutor
SFP Tranceiver for 1000BASE-BX10
So I recently tried some of my many SFP-BiDi Modules (BX10) but they either are rejected straight away or no link up is happening on them (physical works, but nothing else). I tired a Ubiquiti tr...
DooMMasteR
Aug 01, 2021Tutor
I have also tried 2 different Netgear Modules and the switch does not with with them either... There seems to be a serious issue with the firmware.
Will try the firmware rollback later... But that is obviously not a real solution.
schumaku
Aug 02, 2021Guru - Experienced User
Strange. The GC110P's at my customers site with a single original Cisco OEM branded SFP module on port #10 does still serve the fiber link well ongoing with the recent update to 1.0.5.35 on June 9th to some MS510TXUP with 1.0.4.1 for example.
- DooMMasteRAug 02, 2021TutorI can try to bisect the firmware that creates the issue for me.. but since this is mostly a community forum and there is little chance it gets any actual attention and a fix I see little use in it.
I. Now using an earlier firmware and at least it is working...
I do not doubt that there might be modules out there also working with current builds, but I have none of those, so it is of very little use to me.
