Jeremyse
Mar 26, 2020Tutor
Switches vlan not passing dhcp
I’m having a difficult time configuring VLAN routing or some semblance of it on my network. Currently I have a: GC728X - core switch GC728 XP- leaf switch GC510 PP -access Switch NW GC108P- a...
- Apr 01, 2020
Please make sure that all of the uplinks are assigned as T or Tagged on their designated VLAN in order for you to pass through those VLANs on your SSIDs.
You may try to test it first by connecting your PC to one of the ports of the 2nd switch and let it request an IP to your VLAN by using dynamic settings. If it did work, then that's the time that you will try to configure your AP.
May you be able to share your network topology and also screenshots?
John
NETGEAR Community Team
JohnC_V
Apr 01, 2020NETGEAR Employee Retired
John
