Jollyglow
Jan 14, 2024Follower
Unable to start RMA process
Dears, I'm trying to request replacement of a GS108Tv2 switch under lifetime warranty. Its PD port for PoE power delivery appears to be broken. The switch does not accept PoE power and I need to ...
- Jan 14, 2024
Give an alternate contact a try - https://my.netgear.com/support/contact.aspx#
The 802.3af (or 802.3at, 802.3bt, ...) PSE is able to power other PD using the same port and cable?
schumaku
Jan 14, 2024Guru - Experienced User
