XSO
Apr 05, 2022Initiate
BR200 Communicate between two LANs
Hello,
I use a BR200 router I don't want to connect to the Internet (and I don't have access).
I want to connect two networks. LAN1: 193.210.10.0/24 and LAN2: 192.168.10.0/24
I want the BR200 to be used to create routes between these two networks.
I was thinking of connecting LAN 1 to port 1 of the BR200. And the LAN2 on port 2 of the BR200. Purpose: To PING a PC that is on LAN 1 (193.210.10.90) using a PC that is on LAN 2 (192.168.10.10). How should I go about establishing this link?
Thank you in advance
Cordially
XSO
1 Reply
- JeraldMNETGEAR Employee Retired
