RobinFloyd
Apr 26, 2018Follower
Can an Insight devices be moved to another location?
Explorer crashed as I entered - so my apologies if this is a duplicate. Is there an easy way to drag/drop a wireless managed device from one location to another? I know I can unjoin it from managed m...
schumaku
Apr 28, 2018Guru - Experienced User
No, you missed nothing.
RobinFloyd wrote:
I know I can unjoin it from managed mode and re-join, but you have to be onsite to do that. Would love to be able to do it with the cloud console.
For security reasons, the discovery must be run on the same connected (W)LAN. I understand your request - not so long ago a new device was silently added to the last used Network (site, location, ...) instead the intended one. Happened to us several times. For some Insight 4 updates, the system does ask to which Network the new discovered device should be added.
