picacud
Jul 27, 2023Follower
Can't login to Orbilogin.com after using the Insight App
Recently, I tried to find a way to swap my 5G Wi-Fi to other channels through the Insight App. However, there are a few options on the Wi-Fi setting page( not even with the SSID Separation on the fir...
schumaku
Jul 27, 2023Guru - Experienced User
picacud wrote:
I can't log in to Orbilogin.com with my username and password after using the Insight App.
On the Insight App, click on [Location] then go to [Location Configuration] ... there you can set (and see) the local admin password you configured initially (!!!). The same fixed username admin is retained all over, as before.
Edit: The password fields you showed on your screenshots apply for the wireless SSID configuration only, and are never used for any kind of login. Avoid confusion by mixing up the local login with the Netgear Account login used on the Apps and here on the community.
