Dgillet
Apr 18, 2026Tutor
Cloud portal unaccessible
Hi The new cloud portal only uses the mobile phone number to send the verification code. The option to use the email address isn’t available anymore. I’m left out because the sms never worked. I...
- Apr 27, 2026
Thank you for this.
I found the solution.
In the "main" Netgear website, I changed the TFA method to email. It works with the Insight portal too.
Dgillet
Apr 26, 2026Tutor
"Media upload in progress... Please wait..."
schumaku
Apr 26, 2026Guru - Experienced User
Yalla yalla. This feature allowing copy-paste of images is broken since around the beginning of 2026. Store images elsewhere, publicly accessible, a d post the link here.
No idea if the SaaS provider or Netgear with their external directory implementation is in charge. They fighting a long time (and probably still suffer) for customers accessing with dual stack IPv4/IPv6.
- DgilletApr 27, 2026Tutor
Thank you for this.
- schumakuApr 27, 2026Guru - Experienced User
Key to the Netgear "universe" for any kind of authentication is the MyNetgear Account - is the Netgear User Profile (top right of the Web pages) referred from the "main" netgear.com pages, too.
From these pages, after the login, head to -> Manage Profile (don't be confused with the profile on the Netgear Community); then go to -> Login Settings -> Two Step Verification
Correct, Insight (no matter if we talk of the Web Portal, the iOS reap. Android Apps) is directly linked to your Netgear Profile.
The only "unsharp" point (also to me...) is why the authentication to the Insight Portal is locked to the Email+Password; and does not give the alternate option to choose 2FA [SMS] <-> [Email] - for both the [Login] as well as for the [Log In With One-time Passcode].
Happy you have recovered your access to Insight now.
-Kurt.
