Dgillet
Apr 18, 2026Tutor
Cloud portal unaccessible
Hi The new cloud portal only uses the mobile phone number to send the verification code. The option to use the email address isn’t available anymore. I’m left out because the sms never worked. I...
- Apr 27, 2026
Thank you for this.
I found the solution.
In the "main" Netgear website, I changed the TFA method to email. It works with the Insight portal too.
Dgillet
Apr 27, 2026Tutor
Well, the question is "why did the option disappear in the new version?".
The answer might be a label "Work in progress".
schumaku
Apr 27, 2026Guru - Experienced User
As mentioned before: Have not seen such an option on the Insight Web portal since the early Beta days.
Can you please share an old screenshot please, using sone clout photo or image sharing service plus?
