Dgillet
Apr 18, 2026Tutor
Cloud portal unaccessible
Hi The new cloud portal only uses the mobile phone number to send the verification code. The option to use the email address isn’t available anymore. I’m left out because the sms never worked. I...
- Apr 27, 2026
Thank you for this.
I found the solution.
In the "main" Netgear website, I changed the TFA method to email. It works with the Insight portal too.
Dgillet
Apr 27, 2026Tutor
An old screenshot.... I'm afraid that the product is out of stock :-)
But it did exist and worked perfectly. Otherwise the issue I mentioned at the beginning would have been present for quite some time... but wasn't.
