MJ_Mnisi
Apr 08, 2021Follower
Enabling 2.4Ghz radio on a netgear Wac510 dual router
Hi all I have a Netgear Wac510 dual band router in our offices,some android cellphones are unable to connect to the Wifi since well they use a frequency of 2.4Ghz, iPhone users are able to access...
natriot
Apr 08, 2021Aspirant
DETAILS REVIEWS
Remote Mini Super Bass Speaker - BlueSupport: Bluetooth, TF card, USB, FM Radio, Line inSupport telephone redialBluetooth controller 20-15MIt can uphold music designs: , WMA,WAV, PE,FLACHigh affectability FM radio with inside antenna.Material: ABS Plastic + AluminumBuilt-in Li battery-powered battery 350mAH8) Battery can uphold play time: 2hours;Speaker size: 62*53 MM Support without hand when answer calling (with MIC)Auto Voice Prompt force on/off and Bluetooth
