Sweetjanaya1's avatar
Sweetjanaya1
2.4GHZ Band not broadcasting
My 2.4GHZ is not broadcasting it was working fine then it just disappeared. It is enabled and showing a green light on the modem
  • FURRYe38's avatar
    Has a power off for 1 minute then back ON with the ISP modem and router been performed?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
    https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
  • Which router model?
    Which firmware version?
    Is firmware auto-update enabled?
    Is Smart Connect enabled?
    • Sweetjanaya1's avatar
      Sweetjanaya1
      The model is C6300v2 but where do I find the answer to the last 3 questions?
      • michaelkenward's avatar
        michaelkenward
        You can ignore them. Now that we know you have a C6300v2 cable modem/router we know that the firmware is beyond your control.
        For the last question, "Is Smart Connect enabled?" here too your modem router does not support it.
        That's why we asked for more details.
        So it is back to you to provide more information.
        Again it helps to look at the manual:
        Visit the support pages:
        Support | NETGEAR
        Feed in your model number and check the documentation for your hardware.
        Look for a sections in the manual Specify Basic WiFi Settings and Troubleshooting.
    michaelkenward
    If it is a "smart" router and you have "Smart Connect" enabled, you will see only one SSID for 2.4GHz and 5 GHz. Wifi clients then pick the best for them.
    Manuals are always a good place to start.
    Support | NETGEAR
    Look for the model number on the label on the device.
    Look for a section in the manual for something like Smart Connect.
