Sololion
Jan 22, 2024Aspirant
Failed to Activate Captive Portal in Netgear Insight
I am setting a WiFi network with organization-wide SSID enabled. When I try to enable the Captive Portal, an error message "Only alphanumeric characters and special characters !"#$%&'()*+,-.\/:;<...
Sololion
Jan 25, 2024Aspirant
Hi BrianL
Really thanks for your previous advices.
I have further go through a checking on my EULA, and discovered that the portal declines any special characters listed in the error message be included in my EULA.
In another word, the system allows my to use "By using the WiFi service provided by our organization" as my EULA, but prohibits me to use "By using the WiFi service provided by our organization,". The last "comma" trigger the error message. Maybe this is a bug?
