Nkennedy08
Jul 13, 2020Aspirant
Forgot password
Forgot passy
- Jul 13, 2020Forgot passwords
Nkennedy08
Forgot passwords
- plemansJul 13, 2020Guru - Experienced User
For the wifi?
For the login to the device?
We'd need more details.
Or worse case scenario, factory reset it back to defaults. push and hold reset for 7-15 seconds while powered on.
default login: admin
default password: password
or go to netgear.coms/support/
type in your model number and it'll take you to firmware, manuals, troubleshooting that can all be benficial to resolvingg your issue.
