jfrentas's avatar
jfrentas
Follower
Mar 17, 2016
forgot router login password
forgot my password to log in how do i got about recovering it?
  • Hello jfrentas
    The only way to recover it is do a factory reset on the device this will lose all settings you have set up. but after a factory reset the login goes back to admin and password for the credientals.
    DarrenM
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello jfrentas
    DarrenM
  • I forget my router password and i dont know how i get new password
    • DarrenM's avatar
      DarrenM
      Hello Maha
      you will have to factory reset your router like I posted above.
      DarrenM
      • hholstine's avatar
        hholstine
        I just got a new Samsung tablet & started setting it up.
        When it asked for the WiFi password that had been set up in 2010 I realized that I could not remember it.
        I have 2 laptops & a smart TV that is using the WiFi but can't proceed with my new tablet set up without connecting it to my WiFi network.
        Help, what can I do???
