MattSellors
Dec 02, 2021Aspirant
GC110P Going Intermittently Offline
I have a network 95% managed by Netgear Insight switches. It’s a GC728XP smart switch at the centre, with 4 nodes with a GC110P at each end. On 2 of the nodes are wifi WAC510. There are another 2 WAC...
- Dec 10, 2021
Finding a loop on a network is pretty easy but it is time-consuming because you need to reconnect all your cables one at a time and find if there are 2 connections coming from the same device that goes into the switch. Another thing is if there is no loop, it is also possible that there is faulty hardware that floods the switch that causes it to reboot.
John
NETGEAR Community Team
MattSellors
Dec 08, 2021Aspirant
Thanks John! With my limited (zero...) knowledge on this, I think a loop is most likely. Can that be caused by the wifi access points? Is there any way of diagnosing a loop? Cheers! Matt
JohnC_V
Dec 10, 2021NETGEAR Employee Retired
John
