THUMP3RZ
Feb 07, 2022Aspirant
Nighthawk AC1900 intermittent drops offline
My AC1900 R7000 has been connected to a new fiber modem with 200/200 upload/downloads.
I use it heavily and WiFi only.
It has been intermittently dropping offline where I have to pull up my app and reboot the router.
I am considering upgrading to a better model and wondered if there is a good recommendation to fix this issue or what would be a good upgrade for this? TIA
THUMP3RZ wrote:
The Nighthawk app says there is no update available. Now the website says there is. I tried doing the update manually via the web but it doesn't work like it should and the website says to use the app. I guess I will just limp along
Do you have screen snips of the errors/problems you're running into?
I frequently use the browser to update.
What fibre ont/gateway is it connected to?
What firmware is on the R7000?
