WFransL
Feb 02, 2022Tutor
GS108Tv3 continues to report "device(s) lost communication with the NETGEAR Insight cloud service"
Just informing and hoping that you can solve the issue My GS108Tv3 switches continue to report "device(s) lost communication with the NETGEAR Insight cloud service" although 'Netgear' reported th...
- Mar 14, 2022
No disconnects over 28 days since I installed FW 7.0.9.5 !!!
DaneA
Feb 02, 2022NETGEAR Employee Retired
Welcome to the community! :)
What Insight subscription do you have?
Was everything working fine before?
Are there any changes in the settings that might have triggered the problem?
DaneA
NETGEAR Community Team
- WFransLFeb 04, 2022Tutor
Insight Premium Subscription
Earlier FW never gave a problem
Settings have not changed
- DaneAFeb 06, 2022NETGEAR Employee Retired
Thank you for your response.
I checked the status of NETGEAR Insight here and everything seems fine. It is possible that your concern is an isolated issue. I suggest you to open a support ticket with NETGEAR Support here at anytime for further investigation.
DaneA
NETGEAR Community Team- WFransLMar 14, 2022Tutor
