WFransL
Feb 02, 2022Tutor
GS108Tv3 continues to report "device(s) lost communication with the NETGEAR Insight cloud service"
Just informing and hoping that you can solve the issue My GS108Tv3 switches continue to report "device(s) lost communication with the NETGEAR Insight cloud service" although 'Netgear' reported th...
- Mar 14, 2022
No disconnects over 28 days since I installed FW 7.0.9.5 !!!
WFransL
Feb 04, 2022Tutor
What Insight subscription do you have?
Insight Premium Subscription
Was everything working fine before?
Earlier FW never gave a problem
Are there any changes in the settings that might have triggered the problem?
Settings have not changed
DaneA
Feb 06, 2022NETGEAR Employee Retired
Thank you for your response.
I checked the status of NETGEAR Insight here and everything seems fine. It is possible that your concern is an isolated issue. I suggest you to open a support ticket with NETGEAR Support here at anytime for further investigation.
DaneA
NETGEAR Community Team
- WFransLMar 14, 2022Tutor
