Filip011's avatar
Filip011
Follower
Nov 06, 2019
How to open logs? How to ping? - Insight
Netgear Insight. This must be a worst software of this kind that I've ever used.
So, the client gives me access to their router. He provides user name and password.
I access the URL but I cannot login, user name and password are incorreect. He is from Australia and he can log just fine with these credentials. But when I try from Serbia, wrong username and password.
Client then provides a TeamViewer session. He can login just fine. I'm logged to the account. I tried to change password as the existing one is 64 characters long, hoping that perhaps is the problem. It says password is incorrect. Lol. I logged out and I press on the eye icon, I can see the SAME password there. But I can't change it. Hm, ok.
I need to check VPN logs as the VPN is not coming up. Logs doesn't exist. Great. So I need to login from inside.
I'm logged to the router through insight and I'm on a PC through TeamViewer on the same LAN network. I can't login to the router interrnally. Wrong username and password.
Wow.
I can't even find Diganostics - like ping, traceroute.
So how can I troubleshoot site to site VPN if I don't have logs? Is there a way to check logs and ping from Cloud Portal.
I'm seriously disgusted with this software. It's all but 'easy' and intuitive. Unbelivable developers' work.
No RepliesBe the first to reply
ProSupport for Business
