SamSawor86
Oct 24, 2018Aspirant
Insight Monitor Capability
Hi All,
I have a couple of question regarding the new insight monitor capability:
1. what level of packet monitoring that the BR500 provided through the cloud access? for example, can I capture the incoming and outgoing Packets? or Can I monitor the type of traffic on my network?
2. can I run a live uplink connectivity monitor and speed test (for internet connection)?
3. can I monitor a number of dropped packets on the specific switch's port?
- DaneANETGEAR Employee Retired
Hi SamSawor86,
Insight 5.1 adds the support for BR500 which includes the following:
- Ability to add router device to Insight.
- Create VPN groups with up to three BR500 devices.
- Creation and management of VPN users, as well as individual client connection with Insight VPN app.
When managing the BR500 through Insight 5.1, you can view detailed information of the device such as:
- Connected Clients
- Statistics
- VPN Users
- Traffic from the device
- VPN groups the device is connected to
With regard to monitoring the type of traffic on the network via Insight, I will need to inquire this. However via Insight 5.1, it detects the traffic through the BR500 as shown in the image below:
3. can I monitor a number of dropped packets on the specific switch's port?With regards to these questions, there is Diagnostics on Insight 5.1. Currently, we do not have a BR500 to specifically check if live uplink connectivity, speed test and packet capture/monitoring can be done via Insight. I'll get back to you after I inquire this.
DaneA
NETGEAR Community Team
- SamSawor86Aspirant
Hi SamSawor86,
I got a feedback from the higher tier of NETGEAR Support. It was confirmed that the following are not possible via Insight:
- Capture the incoming and outgoing packets of BR500.
- Monitor the type of traffic of the BR500 network.
- Run a live uplink connectivity monitor and speed test (for internet connection) of BR500.
- Monitor a number of dropped packets on the specific port of the BR500. It only lists the sent/received packets but not dropped packets.
It would be best to post the following above as feature request for Insight in the Idea Exchange for Business Board here.
DaneA
