Xraptorx
Jul 23, 2022Follower
Management without Insight
I had UniFi in my old house and am building a new place now. I was looking at Netgear for the 2.5gb network gear for my house. I am looking at 5 APs, 4 Cameras, a NAS, 24 port POE 2.5gb switch and PFS...
schumaku
Jul 23, 2022Guru - Experienced User
Insight Premium does start from $0.83 per month and device so it's hard to consider expensive. If you don't need Smart WiFi roaming, PoE scheduling, the most easy management ever, each device can be Web managed locally. Something your "other" low-cost-cloud solution does not offer.
