thanhtrung9086
Apr 09, 2024Follower
Removal from Insight Account
WAC 510, OS Vs: 8.2.1.16 . System hangs and connection to old administrator is lost. I need a fresh install like the original. please help me DaneA or Christian_R
schumaku
Apr 10, 2024Guru - Experienced User
Remove the device from Insight, then execute a factor reset by using the reset button as per the device user manual.
How do I remove a device from my Insight account?
WAC510 — Insight Managed Smart Cloud Wireless Access Point Documentation
Both users you referred are no longer with Netgear, hope you don't mind getting a reply from a non-Netgear community member.
-Kurt.
- Apr 16, 2020Retired_Member
- Jan 12, 2021Retired_Member
