HarmonHodge
Jul 23, 2023Star
Resubscribe for WAX 620
After a year my subscription has expired on the WAX 620. it isn't the easiest to find how to resubscribe. After searching, I find three prices. I chose the $79. per year as I use this at home and not...
- Jul 23, 2023
HarmonHodge wrote:
I can download the firmware to my Mac but cannot I stall it on the wax 620. I also tried logging in directly to see if I could do anything but that fails.What happens when you try?
I see no suggestion in the manual that you have to have a subscription to update the firmware. Indeed, it has instructions on how to do it manually.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manualManually download firmware and update the access point
schumaku
Jul 23, 2023Guru - Experienced User
The WAX610Y can be integrated with the Insight management, along with the WAX620, into the same location of course.
HarmonHodge
Jul 23, 2023Star
Yessir. I have done that. Works great. I purchased the wax620 a year ago and the wax610y recently. Works great. I just lost the ability to up date the wax620 when the support expired. NetGear doesn’t seem to want to take money on weekends and send a key for me to renew. I can download the firmware to my Mac but cannot I stall it on the wax 620. I also tried logging in directly to see if I could do anything but that fails.
Thank you
Harmon
Thank you
Harmon
- michaelkenwardJul 23, 2023Guru - Experienced User
Support | NETGEAR
- HarmonHodgeJul 23, 2023Star
Thank you!
I will cancel that $79.00 order. These work just fine for home and I was able to update the firmware. It was a little tricky as I had to get past the warning trying to access my browser. Once in It let me upload the new firmware I downloaded to the MacBook Pro.
This site is very helpful. I have learned a ton on here from building my home network. This WAX 620 works great as well as the WAX 610Y on the deck.I also have a Netgear switch connected to my AT&T RG. I had to learn about injectors when I bought the 610Y.
Fun messing with this stuff since retiring.
Thanks everyone.
Harmon
Browsers are getting increasingly picky. They hate http sites, but https is itself a problem with local things on your own network.
I get the impression that router makers and browser builders don't talk to each other.
Glad it worked.
