HarmonHodge
Jul 23, 2023Star
Resubscribe for WAX 620
After a year my subscription has expired on the WAX 620. it isn't the easiest to find how to resubscribe. After searching, I find three prices. I chose the $79. per year as I use this at home and not...
- Jul 23, 2023
HarmonHodge wrote:
I can download the firmware to my Mac but cannot I stall it on the wax 620. I also tried logging in directly to see if I could do anything but that fails.What happens when you try?
I see no suggestion in the manual that you have to have a subscription to update the firmware. Indeed, it has instructions on how to do it manually.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manualManually download firmware and update the access point
michaelkenward
Jul 23, 2023Guru - Experienced User
Support | NETGEAR
HarmonHodge
Jul 23, 2023Star
Thank you!
I will cancel that $79.00 order. These work just fine for home and I was able to update the firmware. It was a little tricky as I had to get past the warning trying to access my browser. Once in It let me upload the new firmware I downloaded to the MacBook Pro.
This site is very helpful. I have learned a ton on here from building my home network. This WAX 620 works great as well as the WAX 610Y on the deck.
I also have a Netgear switch connected to my AT&T RG. I had to learn about injectors when I bought the 610Y.
Fun messing with this stuff since retiring.
Thanks everyone.
Harmon
- michaelkenwardJul 23, 2023Guru - Experienced User
Browsers are getting increasingly picky. They hate http sites, but https is itself a problem with local things on your own network.
I get the impression that router makers and browser builders don't talk to each other.
Glad it worked.
- HarmonHodgeJul 23, 2023Star
Thank you, I recently did the https on my web site. Moving from PC to Mac stuff to clean up my website. It is pretty crazy. Check out the www.atlantamafia.com if you like college football equipment trucks. With all of the changes in conferences, I have a bunch of updates to do.
Thank you
Harmon
