bcre3306
Dec 13, 2024Aspirant
Should I disable Mesh
Hi I have 3 WAX610 in my house and they are all connected via POE back to a switch. Should I be disabling the mesh setting in insight since they are all hardwired back to the switch? I would thi...
- Dec 22, 2024
Hi bcre3306,
We’d greatly appreciate hearing your feedback letting us know if the information provided has helped resolve your concern or if you need further assistance.
If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Have a lovely day,
RennaD
Netgear Team
Dec 13, 2024Guru - Experienced User
The mesh allows devices to roam seamlessly. Why would you want to disable it?
- bcre3306Dec 13, 2024Aspirant
In automatic mesh mode it doesn't seem to associate the devices correctly(root/extender). If I assign them and get them running it's fine but if I lose power and they come up out of order they literally go in an endless reboot process until I manually change the order they boot in. I don't think they should do this but that's what has been happening.
- RennaDDec 16, 2024NETGEAR Moderator
Hi bcre3306,
Since all 3 WAX610 are connected via wired connections, enabling Mesh Mode on Insight isn't necessary. Mesh Mode is typically used to extend WiFi coverage beyond the range of a single AP without the need for additional cables.
Have a lovely day,
RennaD
Netgear Team
