bcre3306's avatar
bcre3306
Should I disable Mesh
Hi   I have 3 WAX610 in my house and they are all connected via POE back to a switch. Should I be disabling the mesh setting in insight since they are all hardwired back to the switch?  I would thi...
  • RennaD's avatar
    RennaD
    Dec 22, 2024
    Hi bcre3306,
    We’d greatly appreciate hearing your feedback letting us know if the information provided has helped resolve your concern or if you need further assistance.
    If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    Have a lovely day,
    RennaD
    Netgear Team
ProSupport for Business
