Aristomastrosi's avatar
Nov 18, 2021
Sporadic timeout in internal network to reach BR200/BR500 (see attached network map)
Dear community,   You were very helpful in the past, therefore I try it again. I need some troubleshooting advice on the following after many tries, but the problem persists on my network with 6 ne...
  • Aristomastrosi's avatar
    Aristomastrosi
    Dec 03, 2021
    Finally I found the solution. The issue does disappear once I changed from "Auto Detect" to "Auto Config" in the IPv6 Config of the BR200. It seems that "Auto Detect" is creating this lag every 15min a DHCP lease extension is received from the ISP. I think this is a bug, because auto detect should not bring down the router for 5-15 seconds after such a harmless message.
    Unfortunately I was unable to file a bug report (purchase date older than 3 month). Can anyone help me how to contact netgear that they are aware of that bug? I'm happy to assist.
ProSupport for Business
