Jothredbo's avatar
Jothredbo
Unknown/foreign computer connected in Insight VPN app computer
Hi I manage 3 small networks and use a single BR500 as the VPN router  at the main one (office). I use the Insight Instant VPN software on various  Win 10 Pro PC's to connect to this location  from the other two networks and I have unnervingly noticed on multiple occassions that I am seeing  unknown computers when browsing locally at the client sites. These foreign devices are, if not secured able to be browsed to and downloaded to and from. I notice my firewall software is blocking connections from a number 10.1.xxx.xxx addresses at the same time. I have thoroughly checked the local routers and the netstat connections and there is nothing obvious. The only thing is the firewall blocking of the various 10.1 addresses which are not immediately obvious as insight local addresses? Support looked at this but don't have anything to say at this point. Any help or advice would be appreciated.
  • MrJoshW's avatar
    MrJoshW
    NETGEAR Employee Retired
    Hello,
    The 10.1.x.x addresses would be realted to the Insight VPN connection. As for the devices you are seeing with this address range. Where are you seeing the devices? Is it in the BR500 local gui? Is it on a client computer connection? Can you provide screenshots of where you are seeing the connection?
    • Jothredbo's avatar
      Jothredbo
      I see these on the client side network browser only. Cossini-PC in this example.
      • MrJoshW's avatar
        MrJoshW
        Hello,
        If you log into the BR500 local browser at each site, under the BASIC tab click on attached devices. Do you see these unknown devices listed at all under the attached devices list? Do the devices have an IP address in any of the LAN tabs?
ProSupport for Business
