TE1
May 16, 2018Tutor
WAC505/510 Wi-Fi Bridge implemented - Is Standalone only way to configure (not Insight)?
Getting a network cable to a WAC505 was going to be very difficult, so used WAC505 User manual section "Set up a WiFi Bridge Between Access Points" to configure a WAC510 as a base station and the WAC...
nmhTester
May 16, 2018NETGEAR Employee Retired
Thank you for the feedback, We will look at offering bridge/uplink from AP via radios.
If there are issues with running wires to set up AP, one option is to use Insight and OrbiPro.
If it basic (upto 3 SSID) wireless deploymemts, Total mesh or dedicated 4x4 wireless backhaul OrbiPro maybe one way to go.
It really depends on what is deployment needs. for example, OrbiPro will not support VLANs.
WAC505/WAC510 provides lot more advanced features and can be deployed in large numbers to cover larger office spaces.
- TE1May 17, 2018Tutor
I want to make sure I understand your answer.
1) If WAC505/510 Wi-Fi Bridge is used, we can now only use Standalone mode, not Insight-managed. But, NETGEAR might add capability to configure Wi-Fi Bridge using Insight at some point. Is that right?
2) Is a factory reset the only way to go back to Insight-managed from Standalone mode on WAC505 and WAC510?
Thanks, again.
- TE1May 25, 2018Tutor
Does anyone have an answer for my 2 follow-up questions on 5/17/2018? Thanks.
- RaghuHRMay 28, 2018NETGEAR Expert
In WAC505 you can change the Management mode from standalone to 'Netgear Insight App' managed mode from the Management mode tab. Please check the attached screen. If WAC510 is in AP mode, then also you can do this.
Hope this helps.
Thanks,
Raghu
