TE1
May 16, 2018Tutor
WAC505/510 Wi-Fi Bridge implemented - Is Standalone only way to configure (not Insight)?
Getting a network cable to a WAC505 was going to be very difficult, so used WAC505 User manual section "Set up a WiFi Bridge Between Access Points" to configure a WAC510 as a base station and the WAC...
TE1
May 17, 2018Tutor
I want to make sure I understand your answer.
1) If WAC505/510 Wi-Fi Bridge is used, we can now only use Standalone mode, not Insight-managed. But, NETGEAR might add capability to configure Wi-Fi Bridge using Insight at some point. Is that right?
2) Is a factory reset the only way to go back to Insight-managed from Standalone mode on WAC505 and WAC510?
Thanks, again.
TE1
May 25, 2018Tutor
Does anyone have an answer for my 2 follow-up questions on 5/17/2018? Thanks.
