Dolly5
Aug 26, 2019Follower
Where to a find my PIN or security key
Good Evening, I purchased my router several years ago. I just got a laptop and it is requesting that enter a PIN or connect using a security key instead. I have to idea how to obtain either or where to look for it. Help please. đ„
- MrJoshWNETGEAR Employee Retired
Hello,
Can you verify for me what model is the router?
The PIN would be a WPS PIN - the security key is the same password as you would enter for adding another system e.g. a mobile to the router.
Pretty much unrelated to the community section - your router is unlikely Netgear. Insight managed.
