fannar
Nov 25, 2024Tutor
Accessing Switch UI and Terminal
Hi!
I have few M4250 ProAV switches that I setup using Netgear Engage. I wanted to access both the Switch UI and the Terminal from Engage but I don't have any password as it seems that Engage changes the default ones. What is the procedure for the access?
Thanks!
By default, there is no password on the Netgear Manged switches.
The first time that you have logged in to the controller from Engage, you must have gone through the Engage Onboarding process, a one-time process that lets you set an admin password for the controller and define a default site with switches and network profiles.
- fannarTutor
I have gone through the onboarding and set a password and I can access the Admin UI but not the Switch UI and Terminal from the three dots menu for each switch. The password I entered on the onboarding and that I use to for the Engage app does not work. So it seems that the onboarding does not set the Switch UI and Terminal passwords.
- amcmdavAspirant
Just curious, did you ever get a solution? I just onboarded a brand new M4350 using Engage without having to supply a password. Did the firmware update. But I can't access the switch through terminal, AV UI, or Main UI. Only through Engage. The password I use to login to Engage does not work for those other 3 access methods.
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
