nmarques
Oct 01, 2020Guide
AMX SVSi N2300 w/ M4300
Hello, I have a single-switch deployment I am currently comissioning with a Netgear M4300 and AMX N2300 encoders and decoders. I am experiencing occasional stream freezes on individual decod...
LaurentMa
Oct 01, 2020NETGEAR Expert
Hi nmarques
Thank you for your message, very practical to have your tech support file here. Sorry about your issue, be sure we are going to help you fix it right away. M4300 was tested with AMX on all points out of the box with default configuration (VLAN 1) so when creating another VLAN, exact same parameters must be like default VLAN 1.
The symptoms you are reporting and the logs for "timer expiry/removing membership" would indicate a deficiency with the IGMP max times. Like if the switch was "stopping" the stream for a moment until a new unsollicited report (join) is coming. You don't use the default value for IGMP Snooping and the IGMP Queries times, I can see it in your configuration.
Could you come back to the default values?
Typically for the IGMP Snooping VLAN Configuration:
set igmp groupmembership-interval 5 600
set igmp maxresponse 5 120
Typically for the Querier Configuration:
set igmp querier query-interval 30
set igmp querier timer expiry 100
Everything else seems pretty normal so I would like to see if the above is fixing your issue. Of course, if you want we can directly work on your configuration file if you send it to us at ProAVDesign@netgear.com. Just export it using Maintenance\Export\HTTP File Export\Text Configuration. One our our ProAV Engineers will directly make the changes in the configuration file and return it to you. If not successful, we will schedule a Zoom call and assist you hands-on asap.
Please let us know, I hope this helps -
nmarques
Oct 05, 2020Guide
Some of the settings came from AMX's configuration guides. I ended up having AMX take a look and about the only things we changed were disabling IGMP Proxy Querier Mode and specifying the switch IP as the Querier address instead of 0.0.0.0. After those two changes, the problems went away.
- LaurentMaOct 06, 2020NETGEAR Expert
Thank you very much for the good news. Kindly send the configuration file that you are now using to ProAVDesign@netgear.com (or the tech-support file, as you want), so that we can have a look collectively here as well.
Thanks in advance!
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
