lillyschneider's avatar
Mar 20, 2024
M4300-525 Main UI access
Hallo,
The main UI interface is not accesspile, only the AV works.
I compared the configuration with a similar switch(same model, same firemware version) but found nothing.
The login via https//ip:49151 but also don't works .
Any help?
  • msi's avatar
    msi
    Apr 02, 2024
    Do check if HTTP is disabled and if HTTPS is actually enabled using "show ip http" and if a SSL/TLS certificate is installed (or at least a self-signed certificate is present). The command should show all three information you might be looking for.
    Context: This has happened to me in the past when I restored a configuration onto a replacement switch but wondered why HTTPS wasn't working afterwards only to realized quite a bit later that no certificate was present - hence the switch couldn't actually enable HTTPS (and I also had disabled plain HTTP).
    • msi's avatar
      msi
      Luminary
ProSupport for Business
