lillyschneider
Mar 20, 2024Follower
M4300-525 Main UI access
Hallo, The main UI interface is not accesspile, only the AV works. I compared the configuration with a similar switch(same model, same firemware version) but found nothing. The login via https//ip...
- Apr 02, 2024
Do check if HTTP is disabled and if HTTPS is actually enabled using "show ip http" and if a SSL/TLS certificate is installed (or at least a self-signed certificate is present). The command should show all three information you might be looking for.
Context: This has happened to me in the past when I restored a configuration onto a replacement switch but wondered why HTTPS wasn't working afterwards only to realized quite a bit later that no certificate was present - hence the switch couldn't actually enable HTTPS (and I also had disabled plain HTTP).
schumaku
Mar 20, 2024Guru - Experienced User
Use the OOB and/or the console port instead.
- msiApr 02, 2024Luminary
